Hey All.
This is probably an issue brought up before but wondering if there has been any traction on this. When importing a file by drag and drop TBC crashes if the Layer Manager is open. You can see it very slowly adding each layer from the imported file to the Layer Manager but once the list becomes larger than screen itself TBC just crashes.
Normally pretty diligent in making sure this isnt open but your mind lapses sometimes and its pretty fustrating having to redo everything from your last save.
Cheers
