How do you change the line weight and color of the balance lines for a clear presentation? I can edit the Object Labels text style, but not the line style.
The line weight and color are hard coded. The zero elevation line color follows the setting in the cut fill map and the line weight follows the line weight of layer 0. I would suggest making your own symbol so that you have full control.
tim
