Material layers not working
  • 1.  Material layers not working
    Posted 05-22-2019 23:24
    Anyone ever have your material layers just stop working? Seemingly out of nowhere, I could no longer select material layers in the corridor template outside of finish layer. This is absolutely crippling as far as my road model goes so there must be a way to fix it I just dont know what I did and how to fix it.
  • 2.  Re: Material layers not working
    Posted 05-23-2019 08:39
    Buck
    Can you send the file to Gary Lantaff at gary_lantaff@trimble.com and he will take a look at t for you - I am on PTO today and will likely not have time - please give him a detailed instruction as to what you are seeing / what you are trying to do but cannot. I am on line now but will be going off line shortly.
    You can aso copy me (alan_sharp@trimble.com) and if I get a chance I will try to answer you.
    If you now what you were doing when it stopped working that would also be helpful.
  • 3.  Re: Material layers not working
    Posted 05-23-2019 08:48
    Alan,
    It was way simpler than that. I was using TBC without an internet connection and therefore had no license. I remembered this on the way to work this morning and tested it to see if it worked and it did.
    Is there a list of items somewhere that are not accessible without your license connection? Is there a way to go offline at all?
    No rush to answer this. Hope you’re enjoying your PTO.
    -Buck
  • 4.  Re: Material layers not working
    Hey Buck!  Is it a licensing issue?  Material layers are grayed out if you don't have at least a Survey Advanced license - or an issue with your key, potentially.
