Has anyone else encountered this error when opening the hatch properties in TBC version 5.31
Error Report
Exception Count: 5
Exception Source: System
Exception Type: System.NotSupportedException
Exception Message: HatchPatternConverter cannot convert from System.String.
Exception Target Site: GetConvertFromException
---- Stack Trace ----
System.ComponentModel.TypeConverter.GetConvertFromException(Object value)
System.dll : N 00193
System.ComponentModel.TypeConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object value)
System.dll : N 7887401
Trimble.Vce.ViewModel.CustomControl.Controllers.TypeConverterComboBoxEditController.set_Data(IEmbeddableControlEditData value)
Trimble.Vce.ViewModel.DLL : N 00309
Trimble.Vce.UI.Controls.PropertyGrid.EmbeddableUIElement.PositionChildElements()
Trimble.Vce.UI.Controls.PropertyGrid.DLL : N 00445
Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
Infragistics4.Win.v18.2.DLL : N 00162
Infragistics4.Win.v18.2.DLL : N 00349
Infragistics.Win.UltraWinGrid.RowColRegionIntersectionUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
Infragistics4.Win.UltraWinGrid.v18.2.DLL : N 00025
Infragistics.Win.UltraWinGrid.UltraGridUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
Infragistics4.Win.UltraWinGrid.v18.2.DLL : N 00056
Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive)
Infragistics4.Win.v18.2.DLL : N 00055
Infragistics.Win.ControlUIElementBase.VerifyIfElementsChanged(Boolean verify, Boolean syncMouseEntered)
Infragistics4.Win.v18.2.DLL : N 00045
Infragistics.Win.ControlUIElementBase.get_CurrentCursor()
Infragistics4.Win.v18.2.DLL : N 00038
Infragistics.Win.UltraControlBase.get_Cursor()
Infragistics4.Win.v18.2.DLL : N 00061
System.Windows.Forms.Control.WmSetCursor(Message& m)
System.Windows.Forms.dll : N 00059
System.Windows.Forms.Control.WndProc(Message& m)
System.Windows.Forms.dll : N 01248
System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
System.Windows.Forms.dll : N 00194
Date and Time: 27/08/2020 3:21:58 pm
Machine Name: DESKTOP-K095P0R
IP Address: fe80::597b:653a:3d28:9fbf%8, 2407:7000:8171:c301:145e:9b6:9404:a8ef, 2407:7000:8171:c300::5, 2407:7000:8171:c301:597b:653a:3d28:9fbf, 192.168.1.13, fd70:8a09:33:3400:145e:9b6:9404:a8ef, fd70:8a09:33:3400:597b:653a:3d28:9fbf,
Current User: DESKTOP-K095P0R\gavin
Application Domain: TrimbleBusinessCenter.exe
Thread Name: Office UI Thread
---- Assemblies in AppDomain ----
Assembly Full Name: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Assembly Full Name: TrimbleBusinessCenter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleBusinessCenter.exe
Assembly Full Name: Trimble.Vce.UI.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.DLL
Assembly Full Name: System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Assembly Full Name: System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Assembly Full Name: System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Assembly Full Name: Trimble.Vce.UI.UIManager, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.UIManager.DLL
Assembly Full Name: Infragistics4.Win.UltraWinToolbars.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinToolbars.v18.2.DLL
Assembly Full Name: Trimble.DiskIO, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.DiskIO.DLL
Assembly Full Name: Trimble.Vce.UI.Client, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Client.DLL
Assembly Full Name: System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Assembly Full Name: System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Assembly Full Name: System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Assembly Full Name: Trimble.Vce.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Interfaces.DLL
Assembly Full Name: Trimble.Vce.Services.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Construction.DLL
Assembly Full Name: Trimble.Vce.Services.Tcc, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tcc.DLL
Assembly Full Name: Trimble.Properties, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Properties.DLL
Assembly Full Name: Trimble.Vce.Services.Construction.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Services.Construction.resources.DLL
Assembly Full Name: Trimble.Vce.Services.Tcc.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Services.Tcc.resources.DLL
Assembly Full Name: Infragistics4.Win.UltraWinDock.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDock.v18.2.DLL
Assembly Full Name: Trimble.Vce.UI.BaseCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.BaseCommands.DLL
Assembly Full Name: Trimble.Vce.Data, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DLL
Assembly Full Name: Trimble.Vce.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Core.DLL
Assembly Full Name: TrimbleBusinessCenter.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/TrimbleBusinessCenter.resources.DLL
Assembly Full Name: Trimble.Vce.License, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.License.DLL
Assembly Full Name: Trimble.Vce.Geometry, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Geometry.DLL
Assembly Full Name: Trimble.Vce.Bridge, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Bridge.DLL
Assembly Full Name: PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
Assembly Full Name: WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
Assembly Full Name: PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
Assembly Full Name: System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Assembly Full Name: UIAutomationProvider, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
Assembly Full Name: System.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
Assembly Full Name: Trimble.Vce.ViewModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ViewModel.DLL
Assembly Full Name: Trimble.Vce.Coordinates, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Coordinates.DLL
Assembly Full Name: Trimble.Vce.Persistence, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Persistence.DLL
Assembly Full Name: Trimble.Geodetic.Math, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.Math.DLL
Assembly Full Name: Trimble.CoreX.CSD, Version=2.91.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.CoreX.CSD.DLL
Assembly Full Name: netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/netstandard/v4.0_2.0.0.0__cc7b13ffcd2ddd51/netstandard.dll
Assembly Full Name: Trimble.CoreX.Gdtic, Version=4.60.82.3, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.CoreX.Gdtic.DLL
Assembly Full Name: ReactiveUI, Version=7.2.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/ReactiveUI.DLL
Assembly Full Name: Splat, Version=1.6.2.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Splat.DLL
Assembly Full Name: System.Reactive.Interfaces, Version=2.2.5.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.Interfaces.DLL
Assembly Full Name: System.Reactive.Core, Version=2.2.5.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.Core.DLL
Assembly Full Name: Trimble.Vce.Alignment, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Alignment.DLL
Assembly Full Name: Trimble.Vce.ForeignCad, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ForeignCad.DLL
Assembly Full Name: Trimble.Vce.Data.RawData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.RawData.DLL
Assembly Full Name: Trimble.Geodetic.Optical, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.Optical.DLL
Assembly Full Name: Trimble.Vce.GE.Base, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Base.DLL
Assembly Full Name: Trimble.Vce.Utils, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Utils.DLL
Assembly Full Name: Trimble.Vce.Gem, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Gem.DLL
Assembly Full Name: Trimble.Vce.Collections, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Collections.DLL
Assembly Full Name: Trimble.Vce.Data.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Construction.DLL
Assembly Full Name: Microsoft.Practices.EnterpriseLibrary.Validation, Version=6.0.0.0, Culture=neutral, PublicKeyToken=9d493c709b8014cc
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Validation.DLL
Assembly Full Name: System.ComponentModel.DataAnnotations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll
Assembly Full Name: Microsoft.Practices.EnterpriseLibrary.Common, Version=6.0.0.0, Culture=neutral, PublicKeyToken=9d493c709b8014cc
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.EnterpriseLibrary.Common.DLL
Assembly Full Name: System.Configuration.Install, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration.Install/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll
Assembly Full Name: Trimble.Vce.Data.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SCS.DLL
Assembly Full Name: Trimble.Vce.Data.SCS.Utilities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SCS.Utilities.DLL
Assembly Full Name: Trimble.Vce.Units, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Units.DLL
Assembly Full Name: Trimble.Vce.UI.Controls.PropertyGrid, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.PropertyGrid.DLL
Assembly Full Name: Infragistics4.Win.UltraWinGrid.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinGrid.v18.2.DLL
Assembly Full Name: Infragistics4.Win.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.v18.2.DLL
Assembly Full Name: Infragistics4.Shared.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Shared.v18.2.DLL
Assembly Full Name: UIAutomationTypes, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
Assembly Full Name: Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Assembly Full Name: Trimble.Vce.Scanning, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Scanning.DLL
Assembly Full Name: Sdo.NET, Version=2.9.1.1200, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Sdo.NET.DLL
Assembly Full Name: Sde.NET, Version=2.9.1.1200, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Sde.NET.DLL
Assembly Full Name: Trimble.Vce.Data.MobileMapping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.MobileMapping.DLL
Assembly Full Name: Trimble.Vce.Data.Results, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Results.DLL
Assembly Full Name: WindowsFormsIntegration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
Assembly Full Name: Trimble.Vce.Data.Tests, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Tests.DLL
Assembly Full Name: System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Assembly Full Name: System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Assembly Full Name: System.Web.ApplicationServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.ApplicationServices/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.ApplicationServices.dll
Assembly Full Name: System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Caching/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Caching.dll
Assembly Full Name: Microsoft.Build.Framework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.Build.Framework/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.Build.Framework.dll
Assembly Full Name: System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Assembly Full Name: System.Transactions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
Assembly Full Name: System.Drawing.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
Assembly Full Name: Infragistics4.Win.UltraWinEditors.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinEditors.v18.2.DLL
Assembly Full Name: Infragistics4.Win.Misc.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.Misc.v18.2.DLL
Assembly Full Name: Trimble.Vce.Epm, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Epm.DLL
Assembly Full Name: Trimble.Vce.Hub, Version=1.0.4.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Hub.DLL
Assembly Full Name: System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
Assembly Full Name: System.ServiceModel.Internals, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
Assembly Full Name: System.Runtime.Serialization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Assembly Full Name: System.IdentityModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
Assembly Full Name: System.EnterpriseServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
Assembly Full Name: System.Net.Http, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
Assembly Full Name: System.Runtime.DurableInstancing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.DurableInstancing/v4.0_4.0.0.0__31bf3856ad364e35/System.Runtime.DurableInstancing.dll
Assembly Full Name: System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
Assembly Full Name: System.Web.Services, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Assembly Full Name: SMDiagnostics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
Assembly Full Name: BellbirdInterfaces, Version=1.1.6680.18676, Culture=neutral, PublicKeyToken=e46c466c63fb6536
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/BellbirdInterfaces.DLL
Assembly Full Name: Trimble.Vce.Data.UASMaster, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.UASMaster.DLL
Assembly Full Name: Trimble.Vce.MobileMapping, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.MobileMapping.DLL
Assembly Full Name: Microsoft.Practices.Prism.Mvvm, Version=1.1.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.Prism.Mvvm.DLL
Assembly Full Name: System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.dll
Assembly Full Name: System.ObjectModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ObjectModel/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ObjectModel.dll
Assembly Full Name: Microsoft.Practices.Prism.SharedInterfaces, Version=1.1.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Practices.Prism.SharedInterfaces.DLL
Assembly Full Name: System.Threading.Tasks, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Threading.Tasks/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Threading.Tasks.dll
Assembly Full Name: EntityFramework, Version=6.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/EntityFramework.DLL
Assembly Full Name: log4net, Version=2.0.8.0, Culture=neutral, PublicKeyToken=669e0ddf0bb1aa2a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/log4net.DLL
Assembly Full Name: Trimble.Vce.Data.Import, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Import.DLL
Assembly Full Name: Microsoft.WindowsAPICodePack.Shell, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.Shell.DLL
Assembly Full Name: Microsoft.WindowsAPICodePack, Version=1.1.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.WindowsAPICodePack.DLL
Assembly Full Name: Trimble.Vce.DeviceIo, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.DeviceIo.DLL
Assembly Full Name: Trimble.WPD.Combined, Version=1.0.0.0, Culture=neutral, PublicKeyToken=e3cd747afe5c1369
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.WPD.Combined.DLL
Assembly Full Name: Infragistics4.Win.UltraWinTabbedMdi.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTabbedMdi.v18.2.DLL
Assembly Full Name: Trimble.Vce.GraphicsEngine2D, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GraphicsEngine2D.DLL
Assembly Full Name: System.IO.Compression, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
Assembly Full Name: Infragistics4.Win.UltraWinTree.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTree.v18.2.DLL
Assembly Full Name: Trimble.Vce.Data.Scanning, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Scanning.DLL
Assembly Full Name: Trimble.Tdx, Version=2.9.1.1142, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Tdx.DLL
Assembly Full Name: Trimble.Vce.Data.GNSSData, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GNSSData.DLL
Assembly Full Name: System.Data.SqlXml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.SqlXml/v4.0_4.0.0.0__b77a5c561934e089/System.Data.SqlXml.dll
Assembly Full Name: System.Reactive.Linq, Version=2.2.5.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.Linq.DLL
Assembly Full Name: Newtonsoft.Json, Version=12.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Newtonsoft.Json/v4.0_12.0.0.0__30ad4fe6b2a6aeed/Newtonsoft.Json.dll
Assembly Full Name: Trimble.Identity, Version=1.0.0.0, Culture=neutral, PublicKeyToken=33101ee013558559
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Identity.DLL
Assembly Full Name: Trimble.Vce.UI.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Reports.DLL
Assembly Full Name: Trimble.Vce.ReportEngine, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ReportEngine.DLL
Assembly Full Name: Microsoft.ReportViewer.WinForms, Version=15.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.WinForms.DLL
Assembly Full Name: Microsoft.ReportViewer.Common, Version=15.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.Common.DLL
Assembly Full Name: Microsoft.ReportViewer.ProcessingObjectModel, Version=15.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.ProcessingObjectModel.DLL
Assembly Full Name: Microsoft.ReportViewer.DataVisualization, Version=15.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.ReportViewer.DataVisualization.DLL
Assembly Full Name: Microsoft.SqlServer.Types, Version=14.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.SqlServer.Types.DLL
Assembly Full Name: Trimble.Vce.Reports.Tests, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Reports.Tests.DLL
Assembly Full Name: Trimble.Vce.UI.Wrapper, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wrapper.DLL
Assembly Full Name: Trimble.Vis.PdfImporter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.PdfImporter.DLL
Assembly Full Name: Trimble.Vis.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.Model.DLL
Assembly Full Name: Trimble.Core.CSDUI.MVP, Version=3.1.2.0, Culture=neutral, PublicKeyToken=012f2610d490fd1a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Core.CSDUI.MVP.DLL
Assembly Full Name: Trimble.Core.CSD, Version=2.91.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Core.CSD.DLL
Assembly Full Name: Trimble.Vce.Data.REB, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.REB.DLL
Assembly Full Name: Trimble.Vce.Data.RawData.Tests, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.RawData.Tests.DLL
Assembly Full Name: Trimble.Vce.Data.ComputationEngine2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ComputationEngine2.DLL
Assembly Full Name: Trimble.Vce.Data.Kml, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Kml.DLL
Assembly Full Name: Trimble.Vce.Data.DWG, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DWG.DLL
Assembly Full Name: TD_SwigDbMgd, Version=19.12.0.0, Culture=neutral, PublicKeyToken=5ccc28765cdf0a88
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TD_SwigDbMgd.DLL
Assembly Full Name: TD_SwigCoreMgd, Version=19.12.0.0, Culture=neutral, PublicKeyToken=8e28356228e490a2
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TD_SwigCoreMgd.DLL
Assembly Full Name: Trimble.Vce.SurveyCAD, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.SurveyCAD.DLL
Assembly Full Name: Trimble.Vce.Features, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Features.DLL
Assembly Full Name: Trimble.Vce.FeatureDefinitions, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.FeatureDefinitions.DLL
Assembly Full Name: CommonCore, Version=4.5.9.127, Culture=neutral, PublicKeyToken=385de07dd97ef61c
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/CommonCore.DLL
Assembly Full Name: Trimble.Vis.Tools, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.Tools.DLL
Assembly Full Name: SlimDX, Version=4.0.13.43, Culture=neutral, PublicKeyToken=b1b0c32fd1ffe4f9
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/SlimDX.DLL
Assembly Full Name: TrimbleDataApi, Version=1.1.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleDataApi.DLL
Assembly Full Name: Trimble.Vce.Data.LandXML, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.LandXML.DLL
Assembly Full Name: Trimble.Geodetic.Reductions, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Geodetic.Reductions.DLL
Assembly Full Name: Microsoft.Extensions.DependencyInjection.Abstractions, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.DependencyInjection.Abstractions.DLL
Assembly Full Name: Trimble.Diagnostics, Version=2.0.5.0, Culture=neutral, PublicKeyToken=33101ee013558559
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Diagnostics.DLL
Assembly Full Name: Microsoft.Diagnostics.Tracing.EventSource, Version=1.1.28.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Diagnostics.Tracing.EventSource.DLL
Assembly Full Name: Trimble.Vce.Share, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Client.dll
Assembly Full Name: Trimble.Vce.UI.Client.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.Client.resources.DLL
Assembly Full Name: Trimble.WebUI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=33101ee013558559
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.WebUI.DLL
Assembly Full Name: Gibraltar.Agent, Version=4.5.0.0, Culture=neutral, PublicKeyToken=ca42a1ee8d2e42d3
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Gibraltar.Agent.DLL
Assembly Full Name: System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Assembly Full Name: Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Assembly Full Name: System.Management, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Assembly Full Name: System.Resources.ResourceManager, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Resources.ResourceManager/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Resources.ResourceManager.dll
Assembly Full Name: System.IO.Compression.FileSystem, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression.FileSystem/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.FileSystem.dll
Assembly Full Name: Microsoft.AspNetCore.SignalR.Client.Core, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Client.Core.DLL
Assembly Full Name: Microsoft.AspNetCore.SignalR.Common, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Common.DLL
Assembly Full Name: System.Memory, Version=4.0.1.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Memory/v4.0_4.0.1.1__cc7b13ffcd2ddd51/System.Memory.dll
Assembly Full Name: System.Text.Json, Version=4.0.1.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Text.Json.DLL
Assembly Full Name: System.ValueTuple, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.ValueTuple.DLL
Assembly Full Name: hasp_net_windows, Version=5.11.1.23192, Culture=neutral, PublicKeyToken=56120be447701319
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hasp_net_windows.DLL
Assembly Full Name: System.Text.Encodings.Web, Version=4.0.5.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Text.Encodings.Web.DLL
Assembly Full Name: Microsoft.Bcl.AsyncInterfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Bcl.AsyncInterfaces.DLL
Assembly Full Name: System.Threading.Tasks.Extensions, Version=4.2.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Threading.Tasks.Extensions.DLL
Assembly Full Name: Microsoft.AspNetCore.Connections.Abstractions, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Connections.Abstractions.DLL
Assembly Full Name: System.IO.Pipelines, Version=4.0.2.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.IO.Pipelines.DLL
Assembly Full Name: System.Threading.Channels, Version=4.0.2.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Threading.Channels.DLL
Assembly Full Name: Microsoft.AspNetCore.SignalR.Client, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Client.DLL
Assembly Full Name: Microsoft.Extensions.Options, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Options.DLL
Assembly Full Name: Microsoft.AspNetCore.Http.Connections.Client, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Http.Connections.Client.DLL
Assembly Full Name: Microsoft.AspNetCore.Http.Features, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Http.Features.DLL
Assembly Full Name: Microsoft.Extensions.Primitives, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Primitives.DLL
Assembly Full Name: Microsoft.AspNetCore.Http.Connections.Common, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.Http.Connections.Common.DLL
Assembly Full Name: Microsoft.Extensions.DependencyInjection, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.DependencyInjection.DLL
Assembly Full Name: Microsoft.Extensions.Logging, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Logging.DLL
Assembly Full Name: Microsoft.Extensions.Logging.Abstractions, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Logging.Abstractions.DLL
Assembly Full Name: Microsoft.AspNetCore.SignalR.Protocols.Json, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.AspNetCore.SignalR.Protocols.Json.DLL
Assembly Full Name: System.Runtime.CompilerServices.Unsafe, Version=4.0.6.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Runtime.CompilerServices.Unsafe.DLL
Assembly Full Name: Trimble.Trdm.ServiceManagement, Version=2.7.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Trdm.ServiceManagement.DLL
Assembly Full Name: Trimble.Trdm.Contracts, Version=2.7.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Trdm.Contracts.DLL
Assembly Full Name: Infragistics4.Win.UltraWinStatusBar.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinStatusBar.v18.2.DLL
Assembly Full Name: System.Buffers, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Buffers/v4.0_4.0.3.0__cc7b13ffcd2ddd51/System.Buffers.dll
Assembly Full Name: Infragistics4.Win.UltraWinExplorerBar.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinExplorerBar.v18.2.DLL
Assembly Full Name: System.Numerics.Vectors, Version=4.1.4.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics.Vectors/v4.0_4.1.4.0__b03f5f7f11d50a3a/System.Numerics.Vectors.dll
Assembly Full Name: Trimble.Vce.Data.Machine, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Machine.DLL
Assembly Full Name: System.ServiceModel.Primitives, Version=4.5.0.3, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.ServiceModel.Primitives.DLL
Assembly Full Name: Microsoft.VisualStudio.Diagnostics.ServiceModelSink, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualStudio.Diagnostics.ServiceModelSink/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Diagnostics.ServiceModelSink.dll
Assembly Full Name: System.ComponentModel.Composition, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.Composition/v4.0_4.0.0.0__b77a5c561934e089/System.ComponentModel.Composition.dll
Assembly Full Name: Trimble.Vce.InjectDependencies, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.InjectDependencies.DLL
Assembly Full Name: Microsoft.Extensions.Http, Version=3.1.2.0, Culture=neutral, PublicKeyToken=adb9793829ddae60
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Extensions.Http.DLL
Assembly Full Name: Trimble.Vce.Core.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Core.resources.DLL
Assembly Full Name: Trimble.Vce.ForeignCad.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.ForeignCad.resources.DLL
Assembly Full Name: Microsoft.Win32.Registry, Version=4.1.3.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Win32.Registry.DLL
Assembly Full Name: CsdManagementWrapper, Version=3.0.1.2, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/CsdManagementWrapper.DLL
Assembly Full Name: GeodeticXWrapper, Version=3.0.1.2, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/GeodeticXWrapper.DLL
Assembly Full Name: Trimble.Vce.Coordinates.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Coordinates.resources.DLL
Assembly Full Name: Trimble.Vce.Data.RawData.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Data.RawData.resources.DLL
Assembly Full Name: Trimble.Geodetic.Optical.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Geodetic.Optical.resources.DLL
Assembly Full Name: Trimble.Vce.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Reports.DLL
Assembly Full Name: Trimble.Vce.Data.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Data.resources.DLL
Assembly Full Name: Trimble.Vce.Alignment.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Alignment.resources.DLL
Assembly Full Name: Trimble.Vce.Gem.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Gem.resources.DLL
Assembly Full Name: Trimble.Vce.Data.GNSSData.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Data.GNSSData.resources.DLL
Assembly Full Name: Trimble.Vce.Data.Results.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Data.Results.resources.DLL
Assembly Full Name: Trimble.Vce.Data.Construction.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Data.Construction.resources.DLL
Assembly Full Name: Trimble.Vce.Features.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Features.resources.DLL
Assembly Full Name: Sdm.NET, Version=2.9.1.1200, Culture=neutral, PublicKeyToken=fa7d95db1187f161
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Sdm.NET.DLL
Assembly Full Name: Trimble.Vce.Data.MobileMapping.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Data.MobileMapping.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.UIManager.dll
Assembly Full Name: Trimble.Vce.UI.UIManager.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.UIManager.resources.DLL
Assembly Full Name: Trimble.Vce.UI.PPCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.PPCommands.DLL
Assembly Full Name: nunit.framework, Version=3.10.1.0, Culture=neutral, PublicKeyToken=2638cd05610744eb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/nunit.framework.DLL
Assembly Full Name: Trimble.Vce.UI.ConstructionCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionCommands.DLL
Assembly Full Name: Trimble.Vce.UI.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Hoops.DLL
Assembly Full Name: Trimble.Vce.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Hoops.DLL
Assembly Full Name: hoops_mvo2220_cs14, Version=22.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hoops_mvo2220_cs14.DLL
Assembly Full Name: hoops_stream2220_cs14, Version=22.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hoops_stream2220_cs14.DLL
Assembly Full Name: hics2220_cs14, Version=22.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hics2220_cs14.DLL
Assembly Full Name: Trimble.Vce.GE.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Core.DLL
Assembly Full Name: Trimble.Vce.GE.Sde, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Sde.DLL
Assembly Full Name: Trimble.Vce.UI.ConstructionReports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionReports.DLL
Assembly Full Name: System.Data.DataSetExtensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
Assembly Full Name: Trimble.Vce.Functions.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Functions.SCS.DLL
Assembly Full Name: Infragistics4.Win.UltraWinChart.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinChart.v18.2.DLL
Assembly Full Name: Infragistics4.Win.UltraWinListView.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinListView.v18.2.DLL
Assembly Full Name: Trimble.Vce.UI.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Construction.DLL
Assembly Full Name: Trimble.Vce.UI.ScanningCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScanningCommands.DLL
Assembly Full Name: Trimble.Vce.UI.ScsCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScsCommands.DLL
Assembly Full Name: Trimble.SCS_WorkOrder, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.SCS_WorkOrder.DLL
Assembly Full Name: Trimble.Vce.UI.Features, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Features.DLL
Assembly Full Name: DataInteroperabilityComponent, Version=1.3.0.3, Culture=neutral, PublicKeyToken=3c2e0c2def562052
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/DataInteroperabilityComponent.DLL
Assembly Full Name: Trimble.Vce.UI.GNSS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.GNSS.DLL
Assembly Full Name: Trimble.Vce.UI.SCS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.SCS.DLL
Assembly Full Name: NTJV.UI.CracksControl, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/NTJV.UI.CracksControl.DLL
Assembly Full Name: Sitech.Data.D12D, Version=5.3.11.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase: file:///C:/Program Files/Sitech Construction Systems/Sitech12D_4.0/Sitech.Data.D12D.dll
Assembly Full Name: Trimble.Vce.UI.Wpf, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wpf.DLL
Assembly Full Name: Trimble.Vce.ViewModel.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.ViewModel.resources.DLL
Assembly Full Name: Trimble.Vce.UI.Controls.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.Controls.resources.DLL
Assembly Full Name: Trimble.Vce.TTMetrics, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.TTMetrics.DLL
Assembly Full Name: Trimble.Vce.UI.MobileMappingCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.MobileMappingCommands.DLL
Assembly Full Name: System.Runtime.Serialization.Formatters.Soap, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll
Assembly Full Name: Infragistics4.Win.SupportDialogs.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.SupportDialogs.v18.2.DLL
Assembly Full Name: Trimble.Vce.UI.INetDownload, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.INetDownload.DLL
Assembly Full Name: Trimble.Vce.UI.CoreCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.CoreCommands.DLL
Assembly Full Name: Trimble.Vis.UI.TccCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.TccCommands.DLL
Assembly Full Name: Trimble.Vis.UI.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.Core.DLL
Assembly Full Name: Trimble.Vis.UI.PdfCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.PdfCommands.DLL
Assembly Full Name: Takeoff.UI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.UI.DLL
Assembly Full Name: Takeoff.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.Reports.DLL
Assembly Full Name: Sitech.Data.D12D.UI, Version=2.0.0.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase: file:///C:/Program Files/Sitech Construction Systems/Sitech12D_4.0/Sitech.Data.D12D.UI.dll
Assembly Full Name: Sitech.UI.ADAC, Version=0.0.0.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase: file:///C:/Program Files/Sitech Construction Systems/SitechADAC_4.0/Sitech.UI.ADAC.dll
Assembly Full Name: Sitech.ADAC, Version=0.0.0.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase: file:///C:/Program Files/Sitech Construction Systems/SitechADAC_4.0/Sitech.ADAC.DLL
Assembly Full Name: Sitech.Commands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase: file:///C:/Program Files/Sitech Construction Systems/SitechExtensions_4.0/Sitech.Commands.dll
Assembly Full Name: Sitech.Common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ff366c5cb503f093
Assembly Codebase: file:///C:/Program Files/Sitech Construction Systems/SitechExtensions_4.0/Sitech.Common.DLL
Assembly Full Name: Trimble.Vce.UI.BaseCommands.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.BaseCommands.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.BaseCommands.dll
Assembly Full Name: Microsoft.Scripting, Version=1.2.2.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Scripting.DLL
Assembly Full Name: IronPython, Version=2.7.9.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.DLL
Assembly Full Name: Microsoft.Dynamic, Version=1.2.2.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Microsoft.Dynamic.DLL
Assembly Full Name: IronPython.Modules, Version=2.7.9.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.Modules.DLL
Assembly Full Name: System.ServiceModel.Discovery, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Discovery/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Discovery.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.PPCommands.dll
Assembly Full Name: Trimble.Vce.UI.PPCommands.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.PPCommands.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.INetDownload.dll
Assembly Full Name: Trimble.Vce.UI.INetDownload.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.INetDownload.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionCommands.dll
Assembly Full Name: Trimble.Vce.UI.ConstructionCommands.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.ConstructionCommands.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScsCommands.dll
Assembly Full Name: Trimble.Vce.UI.ScsCommands.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.ScsCommands.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.CoreCommands.dll
Assembly Full Name: Trimble.Vce.UI.CoreCommands.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.CoreCommands.resources.DLL
Assembly Full Name: Trimble.Vce.Services.WeoGeo, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.WeoGeo.DLL
Assembly Full Name: Trimble.Vce.Services.Bentley, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Bentley.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Features.dll
Assembly Full Name: Trimble.Vce.UI.Features.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.Features.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vis.UI.TccCommands.dll
Assembly Full Name: Trimble.Vis.UI.TccCommands.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vis.UI.TccCommands.resources.DLL
Assembly Full Name: Trimble.Vis.UI.PdfCommands.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vis.UI.PdfCommands.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ScanningCommands.dll
Assembly Full Name: Trimble.Vce.UI.ScanningCommands.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.ScanningCommands.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.UI.dll
Assembly Full Name: Takeoff.UI.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Takeoff.UI.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.MobileMappingCommands.dll
Assembly Full Name: Trimble.Vce.UI.MobileMappingCommands.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.MobileMappingCommands.resources.DLL
Assembly Full Name: System.Reactive.PlatformServices, Version=2.2.5.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.PlatformServices.DLL
Assembly Full Name: System.Reactive.Windows.Threading, Version=2.2.5.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/System.Reactive.Windows.Threading.DLL
Assembly Full Name: Trimble.IS.IPPxGate, Version=6.1.0.0, Culture=neutral, PublicKeyToken=62f2fc89c40229e7
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.IS.IPPxGate.DLL
Assembly Full Name: System.ServiceModel.Channels, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Channels/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Channels.dll
Assembly Full Name: System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Web/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
Assembly Full Name: System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Extensions/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.Extensions.dll
Assembly Full Name: System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Activation/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Activation.dll
Assembly Full Name: System.Xaml.Hosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml.Hosting/v4.0_4.0.0.0__31bf3856ad364e35/System.Xaml.Hosting.dll
Assembly Full Name: Microsoft.CSharp, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
Assembly Full Name: MenuManager, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands/RockpileSolutions/MenuManager.pydll
Assembly Full Name: Anonymously Hosted DynamicMethods Assembly, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name: Snippets.scripting, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name: IronPython.Wpf, Version=2.7.9.0, Culture=neutral, PublicKeyToken=7f709c5b713576e1
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/IronPython.Wpf.DLL
Assembly Full Name: TMLValidation, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands/TMLValidation.pydll
Assembly Full Name: interfaces, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Full Name: RPSUtilities, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands/RPSUtilities.pydll
Assembly Full Name: InfragisticsWPF4.Documents.Excel.v18.2, Version=18.2.20182.186, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/InfragisticsWPF4.Documents.Excel.v18.2.DLL
Assembly Full Name: InfragisticsWPF4.Documents.Core.v18.2, Version=18.2.20182.186, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/InfragisticsWPF4.Documents.Core.v18.2.DLL
Assembly Full Name: InfragisticsWPF4.Controls.Grids.XamSpreadsheet.v18.2, Version=18.2.20182.186, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/InfragisticsWPF4.Controls.Grids.XamSpreadsheet.v18.2.DLL
Assembly Full Name: InfragisticsWPF4.v18.2, Version=18.2.20182.186, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/InfragisticsWPF4.v18.2.DLL
Assembly Full Name: InfragisticsWPF4.Undo.v18.2, Version=18.2.20182.186, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/InfragisticsWPF4.Undo.v18.2.DLL
Assembly Full Name: VoiceCommand, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/ProgramData/Trimble/MacroCommands/Trimble/VoiceCommand.pydll
Assembly Full Name: System.Speech, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
Assembly Full Name: Infragistics4.Win.UltraWinSchedule.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinSchedule.v18.2.DLL
Assembly Full Name: PresentationFramework.Aero2, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
Assembly Full Name: PresentationFramework-SystemXmlLinq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
Assembly Full Name: PresentationFramework-SystemXml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
Assembly Codebase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
Assembly Full Name: Infragistics4.Win.UltraWinDataSource.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDataSource.v18.2.DLL
Assembly Full Name: Infragistics4.Win.UltraWinTabControl.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinTabControl.v18.2.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.DeviceIo.dll
Assembly Full Name: Trimble.Vce.DeviceIo.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.DeviceIo.resources.DLL
Assembly Full Name: Trimble.Vce.Data.ScJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.ScJob.DLL
Assembly Full Name: Trimble.Vce.Data.GeneralSurvey, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.GeneralSurvey.DLL
Assembly Full Name: Trimble.Vce.Data.FieldBookJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.FieldBookJob.DLL
Assembly Full Name: Trimble.Vce.Data.MercuryJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.MercuryJob.DLL
Assembly Full Name: Trimble.Vce.Data.TDS, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.TDS.DLL
Assembly Full Name: Trimble.Vce.Data.SpJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.SpJob.DLL
Assembly Full Name: Trimble.Vce.Data.GeoNav, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Geonav.DLL
Assembly Full Name: Trimble.Vce.Data.AshtechJob, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.AshtechJob.DLL
Assembly Full Name: Trimble.WPD.COMTypes, Version=1.0.0.0, Culture=neutral, PublicKeyToken=e3cd747afe5c1369
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.WPD.COMTypes.DLL
Assembly Full Name: Trimble.Vce.Units.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Units.resources.DLL
Assembly Full Name: Trimble.Vce.Interfaces.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Interfaces.resources.DLL
Assembly Full Name: Trimble.NETStandard, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.NETStandard.DLL
Assembly Full Name: Trimble.Vce.InSphere.Reports, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.InSphere.Reports.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.ConstructionReports.dll
Assembly Full Name: Trimble.Vce.UI.ConstructionReports.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.ConstructionReports.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.GNSS.dll
Assembly Full Name: Trimble.Vce.UI.GNSS.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.GNSS.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Takeoff.Reports.dll
Assembly Full Name: Takeoff.Reports.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Takeoff.Reports.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Reports.dll
Assembly Full Name: Trimble.Vce.UI.Reports.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.Reports.resources.DLL
Assembly Full Name: hoops2220_cs14, Version=22.20.0.0, Culture=neutral, PublicKeyToken=5719c287a5a3450e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/hoops2220_cs14.DLL
Assembly Full Name: WSegmentationManager_x64, Version=0.0.0.0, Culture=neutral, PublicKeyToken=c8536b94f39c562b
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/WSegmentationManager_x64.DLL
Assembly Full Name: Trimble.Vce.GE.Hoops, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Hoops.DLL
Assembly Full Name: Trimble.Vce.Hoops.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.Hoops.resources.DLL
Assembly Full Name: Trimble.Vce.UI.Hoops.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.Hoops.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Hoops.dll
Assembly Full Name: Trimble.Vce.GE.Imaging.Gdal, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.GE.Imaging.Gdal.DLL
Assembly Full Name: gdal_csharp, Version=1.0.7284.37396, Culture=neutral, PublicKeyToken=db5a52b08dc5b321
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/gdal_csharp.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Wrapper.dll
Assembly Full Name: Trimble.Vce.UI.Wrapper.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.Wrapper.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Construction.dll
Assembly Full Name: Trimble.Vce.UI.Construction.resources, Version=1.0.0.0, Culture=en-GB, PublicKeyToken=551d74244f0db52e
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/en-GB/Trimble.Vce.UI.Construction.resources.DLL
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.PropertyGrid.dll
Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.dll
