Linestring 2D Snap
  • 1.  Linestring 2D Snap
    Posted 12-05-2019 17:55
    Is there a way to edit a linestring's horizontal coordinate by snapping to a point object without the elevation of the linestring being set to the point's elevation? Essentially, is there a way to 2D snap instead of 3D snap.
    I am trying to edit the horizontal coordinate of an endpoint of a linestring by snapping to a point object but it keeps overwriting the linestring's elevation to the elevation of the point. The workaround I'm using now is to copy the linestring's elevation, snap the linestring's endpoint to the point, paste the original elevation back into the linestring's elevation, and save.
  • 2.  Re: Linestring 2D Snap
    Posted 12-06-2019 10:10
    There is currently not a way to snap to a 3d point and not get the elevation with this command.  The most common use of a linestring is to connect 3d points, so the command has been optimized to minimize the number of clicks to do so.
    The command does allow you to edit the elevation using the following steps.
    In the coordinate control click on a 3d point. The command will advance to allow you to enter the next point.
    Click on the < to the left of "Adding New Segment", this puts you in editing mode for the previous point.
    Click on the elevation and make your change.  Enter "?" to make the point 2d.  This control allows you to use simple math to change the current elevation.  For example, enter +5 after the current elevation to add 5.
    Click save
    Click the middle icon with the green down arrow to return to adding to the current linestring after the last node
    If you want a simpler way to create a linestring that does allow you to enter XY and then Z, run the _Quick Line TML macro.
    For more details on using linestrings refer to the following document.
    Understanding and Using Linestrings.pdf
  • 3.  Re: Linestring 2D Snap
    Posted 12-06-2019 10:28
    Thank you for the quick response. It would be a good feature to have to be able to hold Ctrl, or a similar button, while snapping to a point to enable the use of only the coordinate and not the elevation of a snap.
  • 4.  Re: Linestring 2D Snap
    Posted 01-22-2020 19:41
    I think this is a very good suggestion. Let's have more use of modifier keys to speed up the commands such as this
    Feature request ?
