Tom, Go to Project Settings>Plan View>Grid Line Definition and change to no scale bar. It should not plot, I tested it. This will also remove the scale bar from the bottom left of your plan view screen
There is a better way to plot instead of using the print command, Using dynaviews and plan sets is the way to go. Give me a call when you're free and we can go over it
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/JiveInlineImages/151130.png)
