Leveling loop misclosures
  • 1.  Leveling loop misclosures
    Posted 02-17-2019 14:15
    I need help with leveling adjustment. I need to check error closure in each loop. I have one level line common for two loops. How can I check misclosure in each loop using TBC (Trimble Business Center) program?
  • 2.  Re: Leveling loop misclosures
    Posted 02-27-2019 08:57
    It should be straight forward process in TBC. You should build each loop by using options Merge runs, add/delete setups if needed, if directions of runs aren't the same then you must use custom export/import and a bit of work in excel.
