When using the command "Create Points at Intervals" is there a way to opt out of the "bonus" points that are created at the end of each segment? If not, could this possible be added as an option in the future?
I can submit as an enhancement request - can you give me the reason why the Node Points are a problem or not required? What is the workflow you are trying to create - The more info I can get to support the enhancement request the better
Thanks
