You can create multiple surfaces with no members, change the settings and use the file as a template.
Depending on what a surface is used for you may want to use different settings. When using point clouds you may want to keep the wireframe off, but you probably want to see it in a design surface. When we create an isopach we make it not visible so that you don't have to wait for it to display in order to see the volume computations.
tim
