How to manipulate the display sequence of CAD elements
  • 1.  How to manipulate the display sequence of CAD elements
    Posted 01-31-2020 06:13
    Hello
    I need to manipulate the display sequence of areas. I have to cover some CAD elements, which are below the subscription stamp. How can I manage it? #display sequence cover areas
    kindyl regards
    Frank
  • 2.  Re: How to manipulate the display sequence of CAD elements
    Posted 02-12-2020 09:31
    Use LayerManager and set the "Display Priority" to "Background" for the stamp layer. That will cause the other linework to be "on top" when drawing.
  • 3.  Re: How to manipulate the display sequence of CAD elements
    Posted 05-20-2020 19:59
    There seems to be a bug, at least in V5.30, in applying the display priority settings to sheet views and PDF plots.
    white line set to background
    other color lines set to foreground
    white line set to foreground
    other color lines set to background
    Plan View
    (thanks to no plan view rotation)
    is correct
    is correct
    Sheet View
    refreshed
    is false
    the same as before, by chance correct
    PDF
    correct, by chance
    same as before, now false
