v5.10 Bug - "Select by Hole ID" command icon is red X in Properties of drill hole
  • 1.  v5.10 Bug - "Select by Hole ID" command icon is red X in Properties of drill hole
    Posted 06-25-2019 18:07
    Found in TBC v5.10.7088.19172
    The "Select Hole by ID" command has no icon and appears as a red X in the toolbar of Properties when a drill hole is selected.
  • 2.  Re: v5.10 Bug - "Select by Hole ID" command icon is red X in Properties of drill hole
    Posted 06-26-2019 14:57
    Thanks, Quan. I will enter this as a bug for the dev team.
    David
  • 3.  Re: v5.10 Bug - "Select by Hole ID" command icon is red X in Properties of drill hole
    Posted 06-26-2019 17:52
    Thanks David!  Not sure I knew it existed - kind of a neat command hidden away in the Properties.  Doesn't look like it's available anywhere else in TBC.
