Feature Request - Rotate Plan View
  • 1.  Feature Request - Rotate Plan View
    Posted 11-06-2020 07:09
    Will this ever be added to TBC?
    I'm finishing up a takeoff now where all the design data is rotated 90°. I have to read everything sideways. Not fun at all.
  • 2.  Re: Feature Request - Rotate Plan View
    Posted 11-06-2020 07:38
    Lobbying hard for this. I feel your pain.
  • 3.  Re: Feature Request - Rotate Plan View
    Posted 11-06-2020 08:57
    I'm with you on this one.
  • 4.  Re: Feature Request - Rotate Plan View
    Posted 11-07-2020 06:31
    How many years has it been?
  • 5.  Re: Feature Request - Rotate Plan View
    Posted 11-07-2020 18:24
    At least 4 years. I requested that already 2016/2017 when still working for SITECH.
  • 6.  Re: Feature Request - Rotate Plan View
    Posted 11-07-2020 10:57
    Yes, I know Trimble gets a very large number of feature requests, but this HAS to be number one. I dread North/South corridors in TBC!
  • 7.  Re: Feature Request - Rotate Plan View
    Posted 11-10-2020 13:11
    I forwarded this again to Trimble for Review.
  • 8.  Re: Feature Request - Rotate Plan View
    Posted 11-13-2020 00:45
    it seems only possible with Trimble Connect for windows with the top right icons (left and right arrows in the circle)
  • 9.  RE: Feature Request - Rotate Plan View
    Posted 07-12-2021 20:46
    Just added to 5.51 hope this helps
    Gavin Jones
  • 10.  RE: Feature Request - Rotate Plan View
    Posted 07-12-2021 22:27
    From the other thread:
    Questions:
    1) Is it possible to manually enter the rotation angle? Say 45-00-00 deg or 127-12-52 ?
    2) Does "Ortho Snap Mode" works on the rotated Grid, or does it still work on Global Grid?
    3) When entering coordinates manually as increments, say "@+2, @+2"​, are those deltas calculated on the new rotated Grid or on Global Grid?
    4) Does coordinate picker delta-x, delta-y work on the new rotated Grid, or does it apply deltas on Global Grid?
    Answers:
    1) With this version, you cannot enter a rotational angle.
    2) "Ortho" still a global X,Y direction.
    3) Global calculations
    4) Global calculations
    Marian Plucinski
  • 11.  RE: Feature Request - Rotate Plan View
    Posted 07-13-2021 00:02
    Check out Alan's post
    https://community.myrockpile.com/t/rps-rotate-plan-view-command/1066
    Gavin Jones
