What is needed to create a cut sheet report in TBC? If I have the .xsl style sheet, does the field crew need to do the grading/field work with the robot? Is the style sheet reading from the .job file? Is it possible to manually enter the data into TBC if they used a level or bring in a .dat file if they used a dini? Thanks in advance!
