I am looking at this one and I am not seeing what you think is incorrect here. If I use an interval of 2' and tie at 3:1 from a line that follows the 3D Shape of the end of a road, there will be steps in the sideslope because there are steps in the source line - because over a distance of say 0.01' you have a step of 0.666' (8') and that makes the top of the curb closer to the OG (in a Cut) than the flow line - so you will get a step in the tie slope as a result
What are you thinking is wrong here with the calculations and what do you want it to do instead?
