I have brought this up in the past as well. The work around I was given was to create a spreadsheet and input them through another process, however that process was cumbersome so I just started creating the points in Terramodel and then transferred them over to TBC.
All I'd suggest is to give an option to leave the particular "Create Point" command open. That would eliminate the constant need to reopen the command each time I need to create multiple points. In addition, if I am using a point command that is referencing the same line or alignment, please have the process maintain that same line or alignment so that it does not need to be referenced each time.
