Fixing a vertical shift in a point cloud
  • 1.  Fixing a vertical shift in a point cloud
    Posted 04-23-2019 10:17
    I'm currently working with a Point Cloud that has shifted vertically. On one side the vertical deviation is .02 and on the other side the deviation is roughly 7.50'. Can anyone help as to a way of adjusting this to match both ends to some existing topo on the site?
  • 2.  Re: Fixing a vertical shift in a point cloud
    Posted 04-26-2019 10:06
    Maybe you can use "Create Scan Station" command and register again.
    If it is a scale error, you can modify the scale and export and re-import.
    maybe so ~~
  • 3.  Re: Fixing a vertical shift in a point cloud
    Posted 04-30-2019 16:21
    Hi Chris, what does the point cloud come from, SX10, TX6/8, or just a LAS? Like Junning said, if it comes from an SX10 station, you can create a scan station then register it. If it comes from other sources, it should already be managed by a scan station structure so you just need to register it as usual.
