Hi Tim,
Thanks for your reply, running version 5.20, editing metric template for A0 Plan and Profile, screenshots below:
Right click->Edit highlighted layout
For some reason when the new tab for editing template always opens it defaults to "all" filter, so switch to "my filter", double click mouse wheel and then zoom in on the template. There you can see the doubling up of text forthe reference lines. All the template settings are below which i had to go a different way doing it vs the how to guide posted in the forums by Alan.
On the plan view, the reference lines are found in within the red square, the alignment used for corridor is also visible.
I have shifted the reference lines slightly to make them perpindicular to the alignment in an attempt to try stop the double up happening, however if you move them slightly again to make them not perpindicular then you will see the two crosses for each line as they sit on top of each other when the line is perpindicular.
