Cut Fill map coloring difference from Plan View to Sheet View?
  • 1.  Cut Fill map coloring difference from Plan View to Sheet View?
    Posted 10-02-2020 14:21
    I haven't run into this before so I did some searching on the forum but can't find an answer.  Below is a cut fill map in Plan View but when I view it it in Sheet view (second photo) I get a solid red.  You can see the corner of the lower cut fill map in the first shot that one has no issues when plotted so its not the TBC file as a whole.  Has any one see this?  I've rebuilt the map a few times but same results.
        Plan View
        Sheet View
  • 2.  Re: Cut Fill map coloring difference from Plan View to Sheet View?
    Posted 10-02-2020 21:05
    I would have to see the model to solve what is wrong here - email it to me at alan.sharp@rockpilesolutions.com
  • 3.  Re: Cut Fill map coloring difference from Plan View to Sheet View?
    Posted 10-04-2020 09:56
    There was a plotting defect in 5.31 that was addressed in the 5.32 patch - are you running 5.32?
    I just ran this in 5.32 with no problems at all - if you are not running 5.32 that would be the first thing to try and if that fails for any reason please share the project with me at alan.sharp@rockpilesolutions.com and I will take a look for you
  • 4.  Re: Cut Fill map coloring difference from Plan View to Sheet View?
    Posted 10-05-2020 14:02
    Thank you Alan
    I'll update this afternoon.  In the mean time if anyone is still holding on to 5.31, only having 1 Cut fill map displayed in plan view is a work around.
  • 5.  Re: Cut Fill map coloring difference from Plan View to Sheet View?
    Posted 10-05-2020 15:14
    Apologies - I did not realize your issue was caused by having 2 or more cut fill maps displayed in Plan View. You dont have to change what is visible in Plan View - just create a View Filter that has just the CF Map that you want to Print visible and apply that to the Sheet Set / Dynaview created to control what is visible in Sheet View - that should solve the issue I would have thought at least.
  • 6.  RE: Re: Cut Fill map coloring difference from Plan View to Sheet View?
    Posted 11-15-2023 04:14
    Good morning Alan
    I am having the same issue as the original poster.  I am running TBC V5.91.  In the plan view the CF Map looks great but in the sheet view it shows all the different colours very close together near the cut fill line.  This makes most of the map appear either dark red or dark blue.  I don't have any other cut fill maps displayed.
    Any ideas?
    Fred
    Fred Lusted
