Calculate seven parameters
  • 1.  Calculate seven parameters
    Posted 11-17-2018 20:52
    TGO can calculate seven parameters by site correction, but I did not find that TBC has this function. Does TBC have the function to calculate seven parameters?
  • 2.  Re: Calculate seven parameters
    Posted 11-19-2018 09:14
    Under "tranform survey points" - 5 or 7 parameter adjustments are possible
  • 3.  Re: Calculate seven parameters
    Posted 12-04-2018 06:01
    Thanks! I'll try.
