Can I find CUT FILL ballance ?
  • 1.  Can I find CUT FILL ballance ?
    Posted 04-03-2019 01:07
     I have surface A anb Design B. I need to know how much to move design B up or down to meet CUT/FILL ballance, Does TBC know any function like this?
    thanks for help
  • 2.  Re: Can I find CUT FILL ballance ?
    Posted 04-03-2019 02:46
    I believe you can only use this with takeoff surfaces but try:
    Takeoff Tab -  Balance line or F12 and Analyze Earthwork Balance
    It is not a quick calculation but it will give you the adjustment for the site.
  • 3.  Re: Can I find CUT FILL ballance ?
    Posted 04-03-2019 03:56
    Thanks!
    Unfrtunately it is in Site construction Edition , but this is the option what I was looking for.
    Thanks
  • 4.  Re: Can I find CUT FILL ballance ?
    Posted 04-18-2019 12:35
    Quick note on this. In order to get very accurate site balance,  you will have to add the shrinkage and expansion on the materials.
