I'm not sure what field equipment you're using, but most won't handle hatches, blocks ect. You can explode the hatch before you export, but if it's a complex or dense hatch it could create a larger file size (normally only a problem with older field equipment). TBC can automatically explode blocks upon export, by enabling that option in export dialog, but not hatching.
