How can I offset a surface without using MSI Manager?
  • 1.  How can I offset a surface without using MSI Manager?
    Posted 11-12-2018 14:07
    I have a finished grade surface, is there a way that I can create a copy of the entire surface, but offset 2' below finish grade? I know it was easy in Terramodel, is it easy in TBC?
  • 2.  Re: How can I offset a surface without using MSI Manager?
    Posted 11-12-2018 20:30
    Adam,
    This is how I did it in Ver 4.12
    1) Export out the FG surface as a .DWG
    2) Import the surface.dwg
    3) Convert the 3D faces to linestrings
    4) Run the Change Elevation- Select all the linestings and lower them by -2'
    5) Create new surface from the linestrings.
    Ver 5 has a macro for copying a surface and offsetting it.
    Hope this helps!
    Mike
  • 3.  Re: How can I offset a surface without using MSI Manager?
    Posted 11-13-2018 07:50
    Mike, I've done a similar procedure except I don't do your step 3. Is there a reason to do the conversion to linestrings first? Also it will be nice to have the macro in v5.
  • 4.  Re: How can I offset a surface without using MSI Manager?
    Posted 11-13-2018 08:10
    You can also export as a TTM and then as you reimport it you can explode it if using the Import command vs Drag and Drop - this does the same thing. The v5 Macro will be the way to go once v5 is released.
