Using 'Send to Sync' for non -job files
  • 1.  Using 'Send to Sync' for non -job files
    Posted 04-09-2019 02:56
    Is there a way to sync general stake out data and background maps from TBC to Access 2018 without creating unnecessary job-files?
    When I try and use 'Send to Sync' to get csv or dxf to Access 2018 it demands creation of a job-file. What I want to do is to sync a bunch of stake out data to the field so that operator can then  sync them to whatever is appropriate jobfile in his controller.
    Current workflow risks that I spam the controller w unnecessary job-files.
  • 2.  Re: Using 'Send to Sync' for non -job files
    Posted 04-11-2019 09:45
    Instead of using "Send to Sync", you can send the files directly from Trimble Sync Manager (TSM).
    1. Run TSM.
    2. Click on the Project associated with you files to be sent. This opens up the Project screen with the Job listing of all jobs associated with the Project.
    3. Next to the Project Name, click on the "Properties" button. This opens up the Project Properties page. NOTE: You must be an Admin to see the Properties button.
    4. On the left side of the screen is a menu listing. Click on the "Reference" option. This opens up a page that allows you to add Project files to the associated Project.
    5. Simply Drag and Drop the required files into the box (or click on the "+"). The next time you sync with the project in Access the files are available to all team members assigned to the Project.
    NOTE: Check in the TSM Help to see which files the Project file box will support. CLick on the "?" while in the Properties>Reference screen.
