Label Lines/Points combined with Feature Codes
  • 1.  Label Lines/Points combined with Feature Codes
    Posted 09-12-2018 05:19
    I've have introduced a customer to Advanced Measurement in SCS900 and created a decent FeatureCode-FXL with him.
    Importing it all into BC-HCE is fine, but they would like to export it to a DXF, including the text (IDs).
    This means using the Label Lines / Label Points, but there is only the option to place the labels at a single layer at a time, which mean you lose the coloring from the feature codes.
    Is there a quick way to add the labels to the layers of the objects they are assigned? Other than doing the Label Points / Label Lines based on each layer one at a time?
  • 2.  Re: Label Lines/Points combined with Feature Codes
    Posted 09-12-2018 10:35
    Lasse
    Typically you would use a GIS exporter like Shapefile (Export - GIS - Shapefile) to include your attributes.
    You may try Create Text - Insert Smart Text - Property: Feature Codes - Object: (point, line,surface).
    Set you font and pick your object and place your text.
  • 3.  Re: Label Lines/Points combined with Feature Codes
    Posted 09-17-2018 03:34
    I'm pretty sure they don't want to go the GIS-way.
    As to Create Text, this would again involve a lot of user input - which we are trying to avoid - as the info is already there.
    The labelling works fine, we just need a clever way to add them to the layer of the object being labelled, to retain the color etc defined by the feature code.
