DXF export to Microstation V8i
  • 1.  DXF export to Microstation V8i
    Posted 08-13-2020 06:27
    Does anyone know how to do a DXF export in TBC that, when imported into Microstation V8i, will show the snap-point along with Name and Feature Code for points- without the need for any commands in Microstation?
    Best I have been able to do is:
    Import the .spj-file, use the command "Point Symbol" to add a symbol
    Use the Label Points to create text for Name and Feature Code.
    Export and DXF version 2004.
    However Label Points require Survey Intermediate - is it possible to do above with Surface Modeling?
