Problem reading older .t02 files in TBC
  • 1.  Problem reading older .t02 files in TBC
    Posted 02-06-2019 15:16
    I'm trying to post-process some 2015 .t02 files (baseline processing). They won't import into TBC (v4.1). The error is that TBC can't read the file header. I tried to use Access Services to convert the file but to no avail. Any ideas?
  • 2.  Re: Problem reading older .t02 files in TBC
    Posted 02-09-2019 19:26
    Did you try sending it to Trimble CenterPoint processing to see if that can process the file or if it returns an error as well?
  • 3.  Re: Problem reading older .t02 files in TBC
    Posted 02-11-2019 11:18
    OK, that worked. Thanks Robert. I forgot I had that option.
