I've imported 3D CAD linework for a large highway project that was created from an InRoads DTM. I converted these lines to Linestrings using the elevate lines trick.
There are a select number of lines that have come in with a UCS - I'm not sure why this is? It appears to be random - some of the lines that were created from the InRoads DTM will be unaffected while a couple of lines from the same DTM have the UCS. These lines are not editable - I cannot break or trim them. Is there a workaround for this?
I searched and it seems older versions of the Project Cleanup tool had something to address lines brought in with a UCS, but I'm not seeing that on my tool in v4.11.
Any suggestions appreciated. Thanks!
