Cary: Thanks for the screenshots. Like you I use intuitive file naming conventions to keep everything 'readable'. You are obviously on a power project (Site C?) so the depth your file structure is pretty complex. Mine are not quite that deep usually.
I guess my original question to the Trimble folks comes from a frustrating experience with Access' folder structure. You have obviously mastered it. My objection is that Jobs are all dumped in the same location and when you create them files need to be linked/copied. Forgive my negative attitude but after SCS900/Siteworks this rudimentary by comparison.
In SCS900/Siteworks the data structure is automated. You create a Site, a series of designs, sync to the controllers and that's it. This is usually done in TBC in the office but can be done in the field if needed. SCS900/Siteworks automatically spits out Machine Control in the field if needed as well. I have attached a screenshot of the data structure. There is zero need to copy or link anything in SCS900/Siteworks. All Work Orders (1000's if needed) get their own folder No copying to an export folder required. This is where I have very "readable" folder names (EG 190221 AB SG 100+00 To 200+00 Rt MCC = Date, As-Built, Subgrade, Station Range, Surveyor's Initials). Designs can be as complex and as deep as needed. In the field you create a Work Order (a Job in Access) and in the process choose a design if needed. That's it, go to work. There is ZERO copying or linking of anything. At the end of the day sync the controllers to the office (using whatever connections you use) and that's it.
The other awesome feature with SCS900/Siteworks is that for most tasks little, or nothing, needs to be done to the output from a Work Order. SCS900/Siteworks creates an output file called an .spj file. It is a data rich format (sort of like a .vcl file in TBC). Measured surfaces sometimes need to be trimmed and some linework cleaned up but basically the data is as measured/collected in the field. No playing with points to create surfaces etc in the office. You get to play with CSV files only if you want to...
It kind of escapes me why new equipment so obviously useful for construction surveyors (ie the SX10) is reliant upon software that is, sorry to say, kind of old fashioned and outdated (yes, even Access 2018).
Ok, I'll stop raving
Thanks for the peek at your data structure. I can see I have some thinking to do about organizing my (future) Access files. Have a good weekend.
Marshall
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/JiveInlineImages/143285.png)
