TBC v4.10.3 and v5.00.2 Patches Released - February 15, 2019
  • 1.  TBC v4.10.3 and v5.00.2 Patches Released - February 15, 2019
    Posted 02-21-2019 09:10
    Version update: Trimble Business Center patch versions 4.10.3 and 5.00.2 now available
    15 February 2019
    If you are currently running TBC version 5.0x, you can update to the new TBC version 5.00.2 by selecting Support > License > Check for Updates.
    If you are currently running TBC version 4.10.x, you can update to the new TBC version 4.10.3 by selecting Support > License > Check for Updates.
  • 2.  Re: TBC v4.10.3 and v5.00.2 Patches Released - February 15, 2019
    Posted 03-22-2019 12:49
    Can you not use the Check for Updates for some reason?
    Please advise and I will try to make a download available to you if your corporate IT stops you from using the check for updates process - we prefer not to have multiple ways to do this, so ideally we want all users to be able to do Check For Updates as that is the easiest method to maintain updates for all users - we would like to understand the barriers that you have to using this process and what they stem from.
    Thanks in advance
