This is getting really annoying with large surfaces. After running an Earthworks report and if you want to keep the Isopach for later you have to rename it. That's all good.
But why is this plain name change triggering a full rebuild of the CutFill map. Another 5 minutes just to change a name? Or put another way, spend double the time than actually necessary.
Please fix that!
