Select Points of/along line, Select line members
  • 1.  Select Points of/along line, Select line members
    Posted 11-10-2020 22:01
    Is there a way to select the points a line was defined with, like Terramodels "OfLine" filter? Select Line members?
    I.e. you have some pickup points which are connected with a line string. Now you have new pickup points with a new line string and you want to get rid of the old line and the points it is based of. To select the line is simple, but the points you have to select one by one, or with polygon select. In Terramodel you press "O" and click on the line and all members are selected.
  • 2.  Re: Select Points of/along line, Select line members
    Posted 11-11-2020 10:39
    The only way I can think of doing this is create a selection set and add the points to a selection set you create.
  • 3.  Re: Select Points of/along line, Select line members
    Posted 11-11-2020 10:43
    Ronny: With linestrings from a topo survey (using SCS900/Siteworks) I just rename the layer on import of the spj file and then "select by layer".
    It's a workaround but saves having to select the nearly invisible line points after deleting the line...
    Marshall
  • 4.  Re: Select Points of/along line, Select line members
    Posted 11-14-2020 20:35
    There is no select using Of Line or Near line as there was in Terramodel at this time.
    Selecting using Polygon Select, Advanced Select, Select by Layer or Select by Rectangle etc. are the only options today.
