Downgrade TA version
  • 1.  Downgrade TA version
    Posted 09-25-2020 12:49
    Can we downgrade form TA 2020.10 to TA 2019.11 using TIM.
    Is there any precautions we have to take for doing so?
  • 2.  Re: Downgrade TA version
    Posted 09-28-2020 07:40
    It's probably possible, though I'm unsure what it'd do to your JOB files.  Since when you went to TA2020 it upgraded all JOB files to the current general survey version. The Trimble JOB converter is for upgrading files to a newer version and not saving files as an older version.  It is possible if you switch to TA 2019 that your JOB files could not be opened without converting them to a JXL file which essentially makes data into coordinates and not bringing any raw data with it.
  • 3.  Re: Downgrade TA version
    Posted 09-28-2020 08:20
    Thank you Robert.
