After you have calibrated your project, go to EXPORT. Click the SURVEY tab, pick Trimble Access job file exporter, select the points you want to export. I usually select the DISTANCE UNITS based off my project, grid for the OUTPUT SYSTEM and the FILE VERSION based off what the individual TSC3. This creates a JOB file that has the TBC project calibration.
