i have a R-10 GPS I WOULD LIKE TO KNOW HOW TO UPPLOAD A DXF FILE (TO USE AS A MEASUREMENT BOUNDARY)
  • 1.  i have a R-10 GPS I WOULD LIKE TO KNOW HOW TO UPPLOAD A DXF FILE (TO USE AS A MEASUREMENT BOUNDARY)
    Posted 11-19-2019 04:56
    I would like to know how to load a drawing in DXF format to my R-10 rover with a TCS3 data collector to use as a measurement boundry (while in the measurement mode)
  • 2.  Re: i have a R-10 GPS I WOULD LIKE TO KNOW HOW TO UPPLOAD A DXF FILE (TO USE AS A MEASUREMENT BOUNDARY)
    Posted 11-19-2019 14:38
    easy! few options-
    • Upload the dxf to a USB stick and then copy to logger
    • Assuming you can connect by cable ( via mobile device centre) plug in the TSC3 - open TBC , if the dxf is present in TBC,  from TBC upload directly
    • you can also drag and drop the DXF onto the TSC3 via explorer
    • Or use Trimble connect to sync?
  • 3.  Re: i have a R-10 GPS I WOULD LIKE TO KNOW HOW TO UPPLOAD A DXF FILE (TO USE AS A MEASUREMENT BOUNDARY)
    Posted 11-19-2019 21:45
    Good morning alan
    thanks for your reply,the Dxf file is in my tcs3 data collector.
    My question is how can i see it on the measurement screen (so that i can see the survey boundaries while topo measurement)
  • 4.  Re: i have a R-10 GPS I WOULD LIKE TO KNOW HOW TO UPPLOAD A DXF FILE (TO USE AS A MEASUREMENT BOUNDARY)
    Posted 11-20-2019 11:42
    You need to add the DXF file as an active map, through the Properties of the job.
  • 5.  Re: i have a R-10 GPS I WOULD LIKE TO KNOW HOW TO UPPLOAD A DXF FILE (TO USE AS A MEASUREMENT BOUNDARY)
    Posted 11-22-2019 10:33
    Or from the map screen , up arrow>layers
  • 6.  Re: i have a R-10 GPS I WOULD LIKE TO KNOW HOW TO UPPLOAD A DXF FILE (TO USE AS A MEASUREMENT BOUNDARY)
    Posted 11-23-2019 22:04
    Good morning
    Thank you very much
    I loaded the map successfully
    Best regards
    Avi shaham
    נשלח מה-iPhone שלי
    אבי שחם
    מודד מוסמך
    054-3171132
