Hi Ted,
Did you want to find-and-replace the entire text content of a text object? i.e. find all instances of "tree" and replace with "Tree"
Or did you want to find-and-replace text within the content of a text object? i.e. find all instances of "pt" and replace with "Point" so that "pt 1" turns into "Point 1" (Using Properties to change the text across multiple objects won't help in this case)
Just curious if Advanced Select + Properties (as mentioned by Saif above) was exactly what you needed.
Thanks,
Quan Mueller
Revenant Solutions | Trimble Community
Independent TML Development - Build. Share. Grow.
