In the Corridors > Alignment Editor, if you check the Advanced box on the Superelevation tab, you can specify a Vertical curve length for a parabolic curve in your superelevation; this will be applied at each break point in the superelevated curve to smooth the transition. The software also draws these vertical curves in the superelevation diagram at the break points. Let me know if there is more to your question.
David
