Enhancement Request - Trim Surface Edge
  • 1.  Enhancement Request - Trim Surface Edge
    Posted 04-02-2019 12:09
    When using the Trim Surface Edge command, I find that nearly every time I am finished with the command that I then need to run the edge breakline command in order to prevent the trimming I just did from being undone by any command that rebuilds the surface.  It would be very helpful if within the Trim Surface Edge command, there was a "done trimming" button that the user can click on when they are done trimming the surface that automatically creates an edge breakline, or at least brings up the edge breakline command.
    #enhancementrequest
  • 2.  Re: Enhancement Request - Trim Surface Edge
    Posted 04-03-2019 07:46
    Good Idea Wayne - will submit to development for Review - agree that it is easy to forget that step and then blow it all up by mistake - better still when you start that command you could create an Edge Breakline automatically in background so that when you are done it already has it there and temporarily ignores it while using that command - because why Trim the Edge if you aren't going to protect it afterwards
  • 3.  Re: Enhancement Request - Trim Surface Edge
    Posted 04-04-2019 06:37
    Even better!
