Corridor crashing TBC
  • 1.  Corridor crashing TBC
    Posted 02-15-2019 08:10
      |   view attached
    I have a corridor in my project that causes TBC to stop functioning whenever I try to edit a template or add a template to it.  I am working in v5.00.1.  I've tried exporting the corridor to a vcl and importing that vcl to a clean project, but get the same problem.  I tried opening the vce file with v4.12 but get the same problem when trying to edit a template.
    My only guess as to the cause is that I deleted the original ground surface that it was using and then replaced it with a new surface of the same name.  I don't know if that would cause this or not.  But whatever the cause is, I am totally unable to view or change the template in anyway.
    I tried to upload the vce file, but it is too large.  I exported the corridor to a vcl which is small enough to upload.  The name of the offending corridor is "Ramp A."  If you create a blank project using standard US Survey Feet template that ships with the software, and import this vcl, you will see the error when trying to edit the template.
    If anyone can offer some insight on what might be wrong with it I will greatly appreciate, I am really pulling my hair out.
    Attachment(s)
    zip
    Ramp A Corridor.vcl.zip   13.06 MB 1 version
  • 2.  Re: Corridor crashing TBC
    Posted 02-15-2019 09:02
    The situation has gotten worse.  I accepted my fate that I just may need to start over, so I deleted the corridor and started a new one, but it does the same thing.  When I try to create a template business center stops working and closes.  Some corridors seem to work fine, but there are others in addition to the one I am currently working on that also are causing it to crash.  I've tried it in v4.12 with the exact same results.
  • 3.  Re: Corridor crashing TBC
    Posted 02-15-2019 09:48
    Some more info:  it appears that this error is occuring in all of my projects on all of my corridors.  I thought some corridors were working, but it was only because the one that seemed to be working starts at a station with no surfaces.  When scrolling down station as soon as it hits a surface Business Center stops working and closes.  It is doing this in all my project files.....files that have been working until today.
    I tried reinstalling business center with no success.
  • 4.  Re: Corridor crashing TBC
    Posted 02-15-2019 13:59
    I don't have much insight for you, but I was able to open your VCL file on my PC and everything works fine for me.  I can edit and add to your template instructions and add new templates, with no crashes.  I was able to create corridor surfaces as well.  Not sure this helps you out, but at least you know it works elsewhere.Corridor
  • 5.  Re: Corridor crashing TBC
    Posted 02-15-2019 14:14
    Your file worked on my 5.01 installation OK Wayne - I was also able to add instructions to the Template OK
    We cannot think of any reason why this could happen on all your files - that indicates that it is either TBC Installation problem or a PC Problem - Maybe it is a config file that remembers all your multi screen and multi view / pane setups that got corrupted somehow when you crashed and that needs to be deleted and reset to defaults
    Delete the contents of the folder at path C:\Users\asharp\AppData\Local\Trimble\Trimble Business Center\31.0 (substitute your username for mine
    Also Delete the contents of this folder - it will get reset and it may mean you have to reset your Options and Linestyles and other User Controlled things, but this may help C:\Users\asharp\AppData\Roaming\Trimble\Trimble Business Center\31.0
    This will get you reset to defaults - let me know if this doesnt work Wayne
  • 6.  RE: Re: Corridor crashing TBC
    Posted 03-13-2022 19:22
    Hi Alan, I am from China TBC need your help, how can I contact you, this is my email
    zhang zhaojun
  • 7.  Re: Corridor crashing TBC
    Posted 02-15-2019 17:45
    So long story short, I got it to work.
    Thank you @Brian Jurgella and @Alan Sharp for input.
    I had tried uninstalling and deleting everything trimble related on my computer, including the folders Alan mentioned.  Then reinstalling TBC and it was still doing it.  I decided to do a Windows system restore back to a date when I knew it was working.  After several hours of that, it was restored and the problem was gone, but a lot of things were screwed up I assume from me having deleted all the trimble stuff.  So I then after having done the windows system restore, then uninstalled all trimble products and reinstalled again.  And now 12 hours later I am back in business.
    Alan, is there anything I might be able to send to you that might indicate what the issue was?  I imagine there probably is not, as it seems like it was an issue unrelated to Trimble.
    Thanks again for the help guys!  I think its time for some medicinal whiskey.
  • 8.  Re: Corridor crashing TBC
    Posted 02-16-2019 10:18
    Wow - it is not uncommon for Windows Update to totally screw you up - I have that issue on my wife's pc to solve this weekend
    Glad you are back up and running Wayne - I don't think this was us - I have never encountered anything like it - although a bad crash can corrupt a windows file so anything is possible
    Have a Whiskey for me
    Sent from my iPhone
  • 9.  Re: Corridor crashing TBC
    Posted 04-07-2019 10:44
    I have the same issue on my laptop. I yet, to figure out whats going on. It crashes when i try to create or edit a template.
  • 10.  Re: Corridor crashing TBC
    Posted 04-07-2019 11:03
    Just found a tread on conflicting software and that is the issue. Thank You WW.
  • 11.  Re: Corridor crashing TBC
    Posted 04-08-2019 06:49
    Could you share the link
  • 12.  Re: Corridor crashing TBC
  • 13.  Re: Corridor crashing TBC
    Posted 04-10-2019 08:59
    I have just started having this same problem yesterday.  Trying to edit a corridor crashes TBC.  Thinking the problem was with the one corridor, so I recreated the corridor.   Restarted, same crash.  Several attempts, same crash. Today, I opened a different project and crashed right after trying to edit the corridor.
    I tried creating a very simple corridor in a new file... as soon as I got the the "edit" template, TBC crashed.
    I tried changing the "graphic display driver", since that has helped problems in the past.  No luck.
    There was an automatic windows update yesterday.
    HELP!!!
  • 14.  Re: Corridor crashing TBC
    Posted 04-10-2019 09:13
    My issues were caused by Turbo Tax install. I uninstalled Turbo Tax and the issue was eliminated.
  • 15.  Re: Corridor crashing TBC
    Posted 04-10-2019 09:31
    Jen
    The only thing that I can suggest is to Restore yesterdays version of
    Windows - we can only test a release on the version of Windows that is
    current at the time of release - if windows does something after that date
    that screws us up, all we can do is try to fix at our next release or get a
    Patch out to solve the problem.
    I will report the issue in - we have heard that Windows Update and TurboTax
    for Desktop are both doing some things that cause us issues - only choice
    is De Install the Updates or programs and work as you were yesterday
    Sorry I cannot help further
  • 16.  Re: Corridor crashing TBC
    Posted 04-10-2019 09:44
    Thank you - uninstalled Turbo Tax and I'm back to work.  I may go to jail if I don't get these taxes filed, but at least I can pay for bail since I'm back to work
    Thank you, Robert Nava, I would not have suspected TT since I have TT 2017 still installed.
  • 17.  Re: Corridor crashing TBC
    Posted 04-10-2019 09:47
    LOL - Nice Jen!
    We wont be seeing you at PUG next week I guess
  • 18.  Re: Corridor crashing TBC
    Posted 04-10-2019 09:43
    You have to finish your taxes and uninstall turbo tax then you should be back in business. Good luck!
  • 19.  Re: Corridor crashing TBC
    Posted 04-10-2019 09:45
    Thanks Wayne!
  • 20.  Re: Corridor crashing TBC
    Posted 05-09-2019 12:44
    The QA Team have now finished their Review of this issue - Here is their response
    The TurboTax 2018 install was corrupting the Microsoft Visual C++ 2017 runtimes used by TBC's Hoops module.
    TurboTax was most likely replacing versions of the Visual C++ 2017 runtimes (possibly with older versions). Uninstalling TurboTax and then re-installing the runtimes provides a temporary fix (until TurboTax is installed again).
    Solution:
    1. Uninstall TurboTax
    2. Re-install the Visual C++ 2017 runtimes:
      1. Uninstall all Microsoft Visual C++ 2017 Redistributables
      2. Re-install the redistributables by browsing to each VCRedist2017_* subfolder where the TBC setup.exe is located.
      3. Run each installer from the subfolder.
    3. Re-launch TBC.
    The runtimes are typically installed to the Windows Component store (WinSxs) which allows multiple versions to co-exist in case a consuming application requires a specific version. TurboTax should not be replacing existing versions but instead install them side-by-side. I have entered defect 67516 if we need to investigate further - this will require purchasing a TurboTax download as there is no trial version available.
    My Final Comment
    There is little to nothing we can do about this - since Turbo Tax is the Corruptor here i guess if you want this problem fixed then you need to ask Turbo Tax to address their issues here. Above is a fix to the problem, we cannot stop them from doing this of course - so I go back to the original recommendation to use Turbo Tax Online or a different program to do your Taxes - since emigrating or hiding from the IRS are not likely great future looking options ....
