Hi, I am using TBC 3.80,
I have a created surface (existing terrain). I have numerous line string objects (Top of concrete foundations)
I want to plot/ label the elevation difference between the line string objects relative to the surface.
I can effectively do what i need to do by creating a new surface which incorporates all the line string objects and then run the Cut/Fill Map module.
This displays the cut/ fill value between the surfaces, this is exactly what i want, but the limitation is that i need to specify a grid, which means the page becomes very congested and uneven as the line string objects are not positioned in a evenly spaced grid.
I want to achieve the same objective but be more selective in my locations to display the cut/ fill value.
Even the Measure tool only allows Point to Surface
Hopefully i am missing something obvious.
Thank you in advance.
