A few questions
1) what coord system do you hqve set or is it a site cal you are using
2) what machines are you sending it to - GCS900 or Earthworks
3) if GCS900 what version of GCS900
4) If GCS what receivers are on the machine ie MS990 or MS992
5) Are you using a Geoiid model
6) what version of TBC are you running
If you could share the ptoject and the site cal or coord system details it would help me to diagnose for you
I don't hqve a quick answer on this unfortunately I will need to be qble to recreate and see for myself and then work some options to see if I can generate a solution for you.
If any other ma hine guys have seen this before please chime in
You can email me at alan.sharp@rockpilesolutions.com
