Hi Alan,
Tx you very much for your precious answer.
So this is a pdf 3d of a section from the operation called "Function of division of surface".
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/JiveInlineImages/144487.png)
It's a nice result but ,a section in a pdf does not have a real meaning. For our division it's better to have a dwg or a jpeg, and you can generate it with the window tool called "capture screen" or also with Powerpoint.
I know that with tbc you can export sections but, you can do it, after the creation of a corridor model.
And sometimes, i need a section without creating the corridor model. Example: I need to create 10 sections on a Gps Survey of a quarry. And, I think that i can not do it right now without creating the corridor model. So I am looking for other ways to do it faster and easily.
Can you tell me more about this?
I am waiting the same exporting operation from the platform "Trimble Stratus" and, again, you can see the section but you can not export it. Just in a pdf report.
Thank you for your time and availability.
SRP
