Why can’t you use the space bar to select multiple points when rotating on the tsc7
  • 1.  Why can’t you use the space bar to select multiple points when rotating on the tsc7
    Posted 12-08-2019 07:13
    In the older tsc versions when rotating you could hold down the space bar to select multiple points which made it easy but in the new tsc7 it just selects and unselects the same point
  • 2.  Re: Why can’t you use the space bar to select multiple points when rotating on the tsc7
    Posted 01-05-2020 16:55
    Are you trying to perform a rotation of all your data or rotate the points visually on the map screen?
    I have not rotated data in a collector before, but have you tried just selecting multiple points on the map screen while in "pointer" mode (black arrow, not the hand)?
