Text Styles
  • 1.  Text Styles
    Posted 01-16-2019 14:20
    Where are the text styles stored that are in the Text Style Manager?  Are they part of the template? Are they persistent across projects, or project specific?
  • 2.  Re: Text Styles
    Posted 01-16-2019 14:26
    The reason I'm asking is for a customer that wants consistent Text Styles across their projects.  So I'm really looking for a method to copy existing Text Styles from one Project to another, I guess.
  • 3.  Re: Text Styles
    Posted 01-16-2019 21:04
    They are stored in the project which means you can create them in your Project template and then use them in all Projects. If you want to move them from one project to another, you have to create a Piece of text using each style that you want to transfer and then VCL out and VCL in the Text Items - The text Styles will carry with the text and you can then delete the text leaving the text Styles behind.
    This is how I do the Drafting templates - that additional sheet set in the template is for all that stuff and that is how they carry into each project.
    Hope that this helps
