I agree that there is an issue with the Plotbox approach however I cannot get the Sheet Output to fail using our PDF output but agree that if you use a third party Print to PDF Driver - what was working in 5.0 is now not scaling correctly in v5.1 - all my Lineweights etc are working and my Print using the Print to PDF function is working OK.
If you are having Lineweight or other Plot Issues - can you send me the project with everything set up so I can test this at my end and try to get this resolved. (alan_sharp@trimble.com)
I still have a question - are you guys downsizing the PDF output to like 300 or 200 DPI when you use the third party print drivers - if you use our Print to PDF and then repeat using the Print Drivers and capture two equivalent files - I would like to receive those to take a look at what you are doing - if you are downsizing - that would explain why the files are "smaller" but I assume at lower resolution (but I assume still acceptable resolution.
I would like to know what you are using as settings for DPI output and the size differences you are seeing - if any of you have time to do that for me I would appreciate it. I would also need to know which print drivers you are using.
I just tried out Nova PDF Report Writer and that allows me to downsize to e.g. 150 DPI which on Letter Size Paper is OK and it makes the file about 2/3 the size of our output - I could likely have gone down to a Lower Resolution like 96 DPI and still got an acceptable output (is this why you are all doing this?)
