I'm trying to plot some cross sections and having trouble making the elevation axis look correct. I would like to be able to stop the axis and labels at the top of the kink row but it goes all the way to the bottom of the table. In terramodel you could enter the datum you wanted the section to start at which solved this but I cannot find how to do this now.
Has anyone come across this problem and found a solution.
Below photo showing what is happening.
