If I want to take some info from one project and put it in another I currently export it as a dxf and then import the dxf into my new project, this feels time consuming and after a while you end up with a load of dxf files to get rid of. Is it possible to copy and paste entities from one .vce project to another, (much like you can in ACAD). Terramodel used to have a function where you could quickly export a very small .tmx file and import that to the new project.
And also it would be great if you could copy objects from ACAD and paste them directly to your tbc project.
If not, any ideas if this is something which may be possible in the future?
