Phillip
You can drag and drop a Site Cal File from SCS900 / Siteworks / Access or a CFG / DC file from a Machine into the Project, that will set up the coordinate system in the project and then you can send the project out to the machines.
If the SCS900 / Siteworks software was set up using Projection and Datum only (No Site Cal) you can drag the DC File into TBC and then send the Coordinate System to the machines.
If you need to create a Coordinate System for the project you can use the SCS900 or Siteworks Emulators on a PC to create the project, Define the Projection and Datum and that will create you a DC file in the Project Sync Folder. You can then drag and drop the DC file into your project and "Voila" you will have what you need.
You can also leave BC-HCE v4.12 on your PC and you can use that to also create the project, add the Coordinate System and save the project and then open it in v5 if you need to do that.
Agreed that the Coordinate System Manager is licensed today.in v5. It takes a lot of time every year to maintain the Coordinate System Manager and keep all of the Global Coordinate Systems up to date so that you can run all of your field systems effectively.
Appreciate that this is a change, please support us as we go through this period of change. We are trying to raise the bar on the software part of the CEC Business, appreciate that you are also likely heavily invested in Trimble Field Technologies.
I hope that you can see that we are investing in providing a higher level of support to our end customers through this Forum and through things like the Power Users Group (2x Training in Colorado in 2019 planned), however all of these things come at a cost unfortunately. I appreciate your feedback.
If you need the Coordinate System Manager functionality in TBC v5 it is now licensed to the Field Data Edition I believe
