Export Corridor surface as TTM
  • 1.  Export Corridor surface as TTM
    Posted 12-19-2018 06:25
    I am noticing that exporting a corridor surface as TTM, then reviewing the TTM, the triangle network does not match the corridor network.  Has anyone else had this issue.  i am trying not to have to explode the corridor and build a free standing surface to export the TTM.
  • 2.  Re: Export Corridor surface as TTM
    Posted 12-19-2018 19:23
    I haven't seen that Ron - do you have the data sets for the project Corridor and output TTM file. Can you give me something more than the two are different - in what way - does the TTM have more or less triangles, do the triangles not follow the breaklines, is it the boundary that is different or ???
    If you could provide screenshots or something for us to review that would be great
    Unfortunately I am off on PTO for the next two weeks - If this is urgent if you could get with Tim or Scott or work this through with Support that would be good. If you want me to take a look I will when I get back. I will have my phone with me so I can take a look at screen shots tomorrow while travelling if you need me to give you some kind of answer here.
  • 3.  Re: Export Corridor surface as TTM
    Posted 12-20-2018 05:56
      |   view attached
    I think I figured out what was going on, there were several surfaces with very similar names.  The one in question was not generated by corridor method it only used breaklines so the triangle mesh was different.
    Thanks for getting back to me and have a great vacation.
    Ron Ciccarone
    SITECH South, LLC
    5375 Oakdale Rd SE
    Smyrna, GA 30082
    Mobile (678) 687-7827 (new mobile)
    Office (404) 505-8181
    PLEASE NOTE EMAIL ADDRESS CHANGE
    ronc@sitechsouth.com<mailto:ronc@cdsinc3d.com>
    <http://sitechsouth.com/evrplus_registration/?action=evrplusegister&event_id=17>
