  • 1.  Splines from designer
    Posted 03-23-2020 07:08
      |   view attached
    When receiving DGN files from the designer we often times get the baselines with splines instead of curves. This results in the geometry being different than what is shown in the plans. So, instead of a 239' Rad on a curve between a PC and PT, I have a series of 4.37' PI segments making up the curve. And the 1637' Rad has 11.325' segments. Is there a way to change this? Right now I just build the baselines manually. I have attached a copy of a report when using their line-work and making it an alignment as an example.
    Attachment(s)
