TBC v5.x Reference Factor Limits
  • 1.  TBC v5.x Reference Factor Limits
    Posted 02-26-2019 19:06
    Hi everyone
    Just wondering if there is a document/ guide/ table showing the upper and lower limits of the pass/fail criteria for the Network Adjustment Network Reference factor (for GNSS Networks)?
    Are these limits fixed or are they statistically generated using adjustment parameters or results?
    Thanks
  • 2.  Re: TBC v5.x Reference Factor Limits
    Posted 02-27-2019 14:32
    Hi Ray,
    The network adjustment command runs a least squares adjustment, which is a complex and potentially confusing topic. For a great explanation on how the network adjustment in TBC works, give the Power Hour a watch from May 2016, titled Network Adjustment Workflows and Best Practices. It can be found here: TBC Power Hour Vault
    Cheers,
    Matt
